Is it possable to set two Wifi details.
I work aways from home and take my Printer with me . Can i setup the details for both Wifi network in the config file..
Paul
Paul
Yep. Just make sure you either play around with a way to obtain the IP address, or statically assigning them. But I push this type of config out to my Pi's so I can move between networks.
In the /boot/octopi-wpa-supplicant.txt file, just start adding in your wifi networks.
Just don't forget to update the country code, and adjust settings as needed. (Scan I think is for hidden networks)
country=US
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
# Home
network={
ssid="SSID-One"
scan_ssid=1
proto=WPA RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="password"
# Work
network={
ssid="SSID-Two"
scan_ssid=1
proto=WPA RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="password"
Thanks Dan .
I really should of know this to be true..
