[Octolapse] Can't install it, no idea why :)
#1
I initially thought I should submit a bug report, but seeing as other people have managed to install Octolapse just fine, I assume it's just me fucking it up somehow.
I made sure to update Octoprint before attempting to install it, but it seems like there's a problem with something called "Pillow" - and I have no idea what that is, nor have I been able to find any documentation on it, other than a forum post about how an alternative to it could/should be used.
I've tried manually downloading the zip and using the upload option inside Octoprint, I've tried SSH'ing the Pi and installing it via the unix(?) command prompt, and I've (obviously, I hope) tried installing it by either copying the path (http://something-something/master.zip) into the octoprint option for that, and just searching and installing it via the built-in plugin search feature in Octoprint.
Here's the most recent log I got:
plugin_pluginmanager_console.log (129.7 KB)
I hope one of you will be able to figure out where I went wrong, or at least point me in the right direction.
Much obliged.
#2
This part wasn't included in the log I submitted (from what I can tell)
Error!
Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
#3
Looks like the problem is installing PIL:
2018-04-14 18:06:07,004 > building 'PIL._imaging' extension
2018-04-14 18:06:07,004 > creating build/temp.linux-armv7l-2.7/src
2018-04-14 18:06:07,005 > creating build/temp.linux-armv7l-2.7/src/libImaging
2018-04-14 18:06:07,018 > src/libImaging/PcxDecode.c: In function ‘ImagingPcxDecode’:
2018-04-14 18:06:07,018 > src/libImaging/Paste.c: In function ‘ImagingFill2’:
2018-04-14 18:06:07,019 > src/libImaging/PcxDecode.c:84:1: internal compiler error: Segmentation fault
Try apt-get install python-pil and then rerunning pip.
#4
Thanks tedder,
not sure what you mean by ”rerunning pip.” but I did the apt-get install python-pil (with sudo in front, because otherwise it would’t let me) and then I tried getting the Octolapse zip via the plugin manager again.
This is the response I got:
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-lmscHG/Pillow/
**Error!**
**Could not parse output from pip, see plugin_pluginmanager_console.log for generated output**
If you want the .log file, let me know.
#5
Yeah, need the logs.
#6
Sorry it took me a while to find this, but I think I have seen this issue before here: https://github.com/FormerLurker/Octolapse/issues/107
The problem is due to low memory/space on the pi, but can be fixed by manually installing pillow from the command line with this command:
pi@octopi:~/oprint/local/bin $ ./pip --no-cache-dir install pillow
Let me know if you need help running the command. Hopefully I find a more elegant way to deal with this soon.
#7
It's really weird, but without doing anything to try and fix this, I tried installing via the plugin manager once more (because I wasn't sure if the log had changed since my last attempt, and I wanted Tedder to have a log where the actual errors appeared) and it just installed, without any problems except for a friendly reminder to update pip. Which I now can't get to update via the suggested "pip install --upgrade pip" command in Kitty.
Sigh...
Octolapse is running though, so I guess I'll stop poking the bear unless one of you fine chaps think it would help you figure something out that I, as a mere mortal, have no idea about. :wink:
plugin_pluginmanager_console (2).log (23.3 KB)
#8
My guess is that you had more system resources available on this attempt, so it just worked. I have heard through the grapevine that there are some memory leak issues with tornado, so perhaps you really did run out of memory?
#9
I just looked through your log, and Pillow installed here:
2018-04-17 19:49:09,049 > Installing collected packages: Pillow, Octolapse
2018-04-17 19:49:09,050 > Running setup.py install for Pillow: started
2018-04-17 19:49:45,511 > Running setup.py install for Pillow: finished with status 'done'
It looks like everything worked fine that time! Let me know if you have other issues.
Plugin Manager not working (self installed Octoprint on Linux)
#10
If you could perhaps explain what I’m doing wrong when I try to update the pip thing, that’d be awesome!
Other than that, I have – so far – not encountered any other issues :blush:
I even made my first timelapse, and it was beautiful, so I’m totally in love with your plugin :smiley:
#11
This should work, but it looks like you tried this:
If it fails when you try, paste the console output here please.
#12
Sure...
-bash: pip: command not found
#13
Jeesh, shows you I am working in my dev environment too much. Try this:
source ~/oprint/bin/activate
#14
That worked like a charm!
As a complete and utter n00b, I have no idea what magic you just had me do, but I’m guessing it has something to do
with that source ~/oprint/bin/activate line. Is that like the old CD command for selecting a directory in Unix? Do I
have to do that line prior to all commands like the upgrade pip one?
Thanks for all your assistance :blush:
#15
@Shuffla Um... activating the virtual environment is like this guy...
JakeSully
...jumping into this...
JakeSully-Device
...and becoming this...
JakeSully-Blue
You just needed to upgrade pip for the blue guy instead of the white guy.
#16
I'm having a similar issue installing OctoLapse. I can't seem to get Pillow to install from Putty command window nor Plugin manager. The log contains too much text to paste. I have no idea what the most important log entries would be to help.
Installing plugin "Octolapse" from https://github.com/FormerLurker/Octolapse/archive/master.zip...
/home/pi/oprint/bin/python -m pip install https://github.com/FormerLurker/Octolapse/archive/master.zip --no-cache-dir
Collecting https://github.com/FormerLurker/Octolapse/archive/master.zip
Downloading https://github.com/FormerLurker/Octolapse/archive/master.zip
Requirement already satisfied: OctoPrint in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==v0.3.1) (1.3.9)
Collecting Pillow (from Octolapse==v0.3.1)
Downloading https://files.pythonhosted.org/packages/d3/c4/b45b9c0d549f482dd072055e2d3ced88f3b977f7b87c7a990228b20e7da1/Pillow-5.2.0.tar.gz (14.5MB)
Requirement already satisfied: sarge in /home/pi/oprint/lib/python2.7/site-packages/sarge-0.1.4-py2.7.egg (from Octolapse==v0.3.1) (0.1.4)
Requirement already satisfied: six in /home/pi/oprint/lib/python2.7/site-packages/six-1.10.0-py2.7.egg (from Octolapse==v0.3.1) (1.10.0)
Requirement already satisfied: flask<0.11,>=0.10.1 in /home/pi/oprint/lib/python2.7/site-packages/Flask-0.10.1-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.10.1)
Requirement already satisfied: Jinja2<2.9,>=2.8.1 in /home/pi/oprint/lib/python2.7/site-packages/Jinja2-2.8.1-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (2.8.1)
Requirement already satisfied: werkzeug<0.9,>=0.8.3 in /home/pi/oprint/lib/python2.7/site-packages/Werkzeug-0.8.3-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.8.3)
Requirement already satisfied: tornado==4.5.3 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint->Octolapse==v0.3.1) (4.5.3)
Requirement already satisfied: PyYAML<3.11,>=3.10 in /home/pi/oprint/lib/python2.7/site-packages/PyYAML-3.10-py2.7-linux-armv7l.egg (from OctoPrint->Octolapse==v0.3.1) (3.10)
Requirement already satisfied: Flask-Login<0.3,>=0.2.11 in /home/pi/oprint/lib/python2.7/site-packages/Flask_Login-0.2.11-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.2.11)
Requirement already satisfied: Flask-Principal<0.4,>=0.3.5 in /home/pi/oprint/lib/python2.7/site-packages/Flask_Principal-0.3.5-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.3.5)
Requirement already satisfied: Flask-Babel<0.10,>=0.9 in /home/pi/oprint/lib/python2.7/site-packages/Flask_Babel-0.9-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.9)
Requirement already satisfied: Flask-Assets<0.11,>=0.10 in /home/pi/oprint/lib/python2.7/site-packages/Flask_Assets-0.10-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.10)
Requirement already satisfied: markdown<2.7,>=2.6.9 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint->Octolapse==v0.3.1) (2.6.11)
Requirement already satisfied: pyserial<3.5,>=3.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint->Octolapse==v0.3.1) (3.4)
Requirement already satisfied: netaddr<0.8,>=0.7.19 in /home/pi/oprint/lib/python2.7/site-packages/netaddr-0.7.19-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.7.19)
Requirement already satisfied: watchdog<0.9,>=0.8.3 in /home/pi/oprint/lib/python2.7/site-packages/watchdog-0.8.3-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.8.3)
Requirement already satisfied: netifaces<0.11,>=0.10.6 in /home/pi/oprint/lib/python2.7/site-packages/netifaces-0.10.6-py2.7-linux-armv7l.egg (from OctoPrint->Octolapse==v0.3.1) (0.10.6)
Requirement already satisfied: pylru<1.1,>=1.0.9 in /home/pi/oprint/lib/python2.7/site-packages/pylru-1.0.9-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (1.0.9)
Requirement already satisfied: rsa<3.3,>=3.2.3 in /home/pi/oprint/lib/python2.7/site-packages/rsa-3.2.3-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (3.2.3)
Requirement already satisfied: pkginfo<1.5,>=1.4.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint->Octolapse==v0.3.1) (1.4.2)
Requirement already satisfied: requests<3,>=2.18.4 in /home/pi/oprint/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (2.18.4)
Requirement already satisfied: semantic_version<2.5,>=2.4.2 in /home/pi/oprint/lib/python2.7/site-packages/semantic_version-2.4.2-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (2.4.2)
Requirement already satisfied: psutil<5.5,>=5.4.6 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint->Octolapse==v0.3.1) (5.4.6)
Requirement already satisfied: Click<6.3,>=6.2 in /home/pi/oprint/lib/python2.7/site-packages/click-6.2-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (6.2)
Requirement already satisfied: awesome-slugify<1.7,>=1.6.5 in /home/pi/oprint/lib/python2.7/site-packages/awesome_slugify-1.6.5-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (1.6.5)
Requirement already satisfied: feedparser<5.3,>=5.2.1 in /home/pi/oprint/lib/python2.7/site-packages/feedparser-5.2.1-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (5.2.1)
Requirement already satisfied: chainmap<1.1,>=1.0.2 in /home/pi/oprint/lib/python2.7/site-packages/chainmap-1.0.2-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (1.0.2)
Requirement already satisfied: future<0.16,>=0.15.2 in /home/pi/oprint/lib/python2.7/site-packages/future-0.15.2-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.15.2)
Requirement already satisfied: scandir<1.4,>=1.3 in /home/pi/oprint/lib/python2.7/site-packages/scandir-1.3-py2.7-linux-armv7l.egg (from OctoPrint->Octolapse==v0.3.1) (1.3)
Requirement already satisfied: websocket-client<0.41,>=0.40.0 in /home/pi/oprint/lib/python2.7/site-packages/websocket_client-0.40.0-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.40.0)
Requirement already satisfied: python-dateutil<2.7,>=2.6.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint->Octolapse==v0.3.1) (2.6.1)
Requirement already satisfied: wrapt<1.11,>=1.10.11 in /home/pi/oprint/lib/python2.7/site-packages/wrapt-1.10.11-py2.7-linux-armv7l.egg (from OctoPrint->Octolapse==v0.3.1) (1.10.11)
Requirement already satisfied: futures<3.2,>=3.1.1 in /home/pi/oprint/lib/python2.7/site-packages/futures-3.1.1-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (3.1.1)
Requirement already satisfied: emoji<0.5,>=0.4.5 in /home/pi/oprint/lib/python2.7/site-packages/emoji-0.4.5-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (0.4.5)
Requirement already satisfied: monotonic<1.4,>=1.3 in /home/pi/oprint/lib/python2.7/site-packages/monotonic-1.3-py2.7.egg (from OctoPrint->Octolapse==v0.3.1) (1.3)
Requirement already satisfied: frozendict<1.3,>=1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint->Octolapse==v0.3.1) (1.2)
Requirement already satisfied: itsdangerous>=0.21 in /home/pi/oprint/lib/python2.7/site-packages/itsdangerous-0.24-py2.7.egg (from flask<0.11,>=0.10.1->OctoPrint->Octolapse==v0.3.1) (0.24)
Requirement already satisfied: MarkupSafe in /home/pi/oprint/lib/python2.7/site-packages/MarkupSafe-1.0-py2.7-linux-armv7l.egg (from Jinja2<2.9,>=2.8.1->OctoPrint->Octolapse==v0.3.1) (1.0)
Requirement already satisfied: singledispatch in /home/pi/oprint/lib/python2.7/site-packages (from tornado==4.5.3->OctoPrint->Octolapse==v0.3.1) (3.4.0.3)
Requirement already satisfied: certifi in /home/pi/oprint/lib/python2.7/site-packages/certifi-2017.04.17-py2.7.egg (from tornado==4.5.3->OctoPrint->Octolapse==v0.3.1) (2017.4.17)
Requirement already satisfied: backports_abc>=0.4 in /home/pi/oprint/lib/python2.7/site-packages (from tornado==4.5.3->OctoPrint->Octolapse==v0.3.1) (0.5)
Requirement already satisfied: blinker in /home/pi/oprint/lib/python2.7/site-packages/blinker-1.4-py2.7.egg (from Flask-Principal<0.4,>=0.3.5->OctoPrint->Octolapse==v0.3.1) (1.4)
Requirement already satisfied: Babel>=1.0 in /home/pi/oprint/lib/python2.7/site-packages/Babel-2.4.0-py2.7.egg (from Flask-Babel<0.10,>=0.9->OctoPrint->Octolapse==v0.3.1) (2.4.0)
Requirement already satisfied: speaklater>=1.2 in /home/pi/oprint/lib/python2.7/site-packages/speaklater-1.3-py2.7.egg (from Flask-Babel<0.10,>=0.9->OctoPrint->Octolapse==v0.3.1) (1.3)
Requirement already satisfied: webassets>=0.10 in /home/pi/oprint/lib/python2.7/site-packages/webassets-0.12.1-py2.7.egg (from Flask-Assets<0.11,>=0.10->OctoPrint->Octolapse==v0.3.1) (0.12.1)
Requirement already satisfied: argh>=0.24.1 in /home/pi/oprint/lib/python2.7/site-packages/argh-0.26.2-py2.7.egg (from watchdog<0.9,>=0.8.3->OctoPrint->Octolapse==v0.3.1) (0.26.2)
Requirement already satisfied: pathtools>=0.1.1 in /home/pi/oprint/lib/python2.7/site-packages/pathtools-0.1.2-py2.7.egg (from watchdog<0.9,>=0.8.3->OctoPrint->Octolapse==v0.3.1) (0.1.2)
Requirement already satisfied: pyasn1>=0.1.3 in /home/pi/oprint/lib/python2.7/site-packages/pyasn1-0.2.3-py2.7.egg (from rsa<3.3,>=3.2.3->OctoPrint->Octolapse==v0.3.1) (0.2.3)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /home/pi/oprint/lib/python2.7/site-packages/chardet-3.0.4-py2.7.egg (from requests<3,>=2.18.4->OctoPrint->Octolapse==v0.3.1) (3.0.4)
Requirement already satisfied: idna<2.7,>=2.5 in /home/pi/oprint/lib/python2.7/site-packages/idna-2.6-py2.7.egg (from requests<3,>=2.18.4->OctoPrint->Octolapse==v0.3.1) (2.6)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in /home/pi/oprint/lib/python2.7/site-packages/urllib3-1.22-py2.7.egg (from requests<3,>=2.18.4->OctoPrint->Octolapse==v0.3.1) (1.22)
Requirement already satisfied: regex in /home/pi/oprint/lib/python2.7/site-packages/regex-2017.06.23-py2.7-linux-armv7l.egg (from awesome-slugify<1.7,>=1.6.5->OctoPrint->Octolapse==v0.3.1) (2017.6.23)
Requirement already satisfied: Unidecode<0.05,>=0.04.14 in /home/pi/oprint/lib/python2.7/site-packages/Unidecode-0.04.20-py2.7.egg (from awesome-slugify<1.7,>=1.6.5->OctoPrint->Octolapse==v0.3.1) (0.4.20)
Requirement already satisfied: backports.ssl_match_hostname in /home/pi/oprint/lib/python2.7/site-packages/backports.ssl_match_hostname-3.5.0.1-py2.7.egg (from websocket-client<0.41,>=0.40.0->OctoPrint->Octolapse==v0.3.1) (3.5.0.1)
Requirement already satisfied: pytz>=0a in /home/pi/oprint/lib/python2.7/site-packages/pytz-2017.2-py2.7.egg (from Babel>=1.0->Flask-Babel<0.10,>=0.9->OctoPrint->Octolapse==v0.3.1) (2017.2)
Running setup.py install for Pillow: finished with status 'error'
Complete output from command /home/pi/oprint/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-qnvAde/Pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-nlSyl9/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/oprint/include/site/python2.7/Pillow:
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'python_requires'
warnings.warn(msg)
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageQt.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/GbrImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/GifImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PdfImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PsdImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PcfFontFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageStat.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/BufrStubImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ContainerIO.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/MpegImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/McIdasImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/_binary.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/TarIO.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PSDraw.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/FtexImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageShow.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/BmpImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/features.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PpmImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/SunImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ExifTags.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageMath.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageChops.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/TiffImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageOps.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/Image.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImtImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/_tkinter_finder.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageGrab.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImagePalette.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PixarImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/WebPImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/IcoImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/XbmImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/IptcImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/JpegImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageFont.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/SpiderImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageMorph.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/MspImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageEnhance.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/XVThumbImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageTransform.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/SgiImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/TiffTags.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PyAccess.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/EpsImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageCms.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PalmImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/TgaImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/BlpImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/FontFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageDraw2.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/GdImageFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/DcxImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PngImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageSequence.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PdfParser.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/CurImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageDraw.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/XpmImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PcdImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/MpoImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageMode.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/FliImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/__init__.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/JpegPresets.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/MicImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/_util.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageWin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageTk.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/IcnsImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImagePath.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PaletteFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/_version.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/WalImageFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/FitsStubImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageFilter.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/GimpGradientFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/WmfImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/BdfFontFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/FpxImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/GimpPaletteFile.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/GribStubImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/OleFileIO.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/DdsImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/PcxImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying src/PIL/ImageColor.py -> build/lib.linux-armv7l-2.7/PIL
running egg_info
writing src/Pillow.egg-info/PKG-INFO
writing top-level names to src/Pillow.egg-info/top_level.txt
writing dependency_links to src/Pillow.egg-info/dependency_links.txt
warning: manifest_maker: standard file '-c' not found
reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.c'
warning: no files found matching '*.h'
warning: no files found matching '*.sh'
no previously-included directories found matching 'docs/_static'
warning: no previously-included files found matching '.appveyor.yml'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.codecov.yml'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.landscape.yaml'
warning: no previously-included files found matching '.travis'
warning: no previously-included files found matching '.travis/*'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
running build_ext
Building using 4 processes
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/_imaging.c -o build/temp.linux-armv7l-2.7/src/_imaging.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/outline.c -o build/temp.linux-armv7l-2.7/src/outline.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Bands.c -o build/temp.linux-armv7l-2.7/src/libImaging/Bands.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/ColorLUT.c -o build/temp.linux-armv7l-2.7/src/libImaging/ColorLUT.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/path.c -o build/temp.linux-armv7l-2.7/src/path.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/BcnDecode.c -o build/temp.linux-armv7l-2.7/src/libImaging/BcnDecode.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Convert.c -o build/temp.linux-armv7l-2.7/src/libImaging/Convert.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Access.c -o build/temp.linux-armv7l-2.7/src/libImaging/Access.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/AlphaComposite.c -o build/temp.linux-armv7l-2.7/src/libImaging/AlphaComposite.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Resample.c -o build/temp.linux-armv7l-2.7/src/libImaging/Resample.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/BitDecode.c -o build/temp.linux-armv7l-2.7/src/libImaging/BitDecode.o
src/libImaging/Resample.c: In function ‘ImagingResampleVertical_8bpc’:
src/libImaging/Resample.c:687:1: internal compiler error: Segmentation fault
#17
Continuing from the last reply:
Then the log contained:
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.9/README.Bugs> for instructions.
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Blend.c -o build/temp.linux-armv7l-2.7/src/libImaging/Blend.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Chops.c -o build/temp.linux-armv7l-2.7/src/libImaging/Chops.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/ConvertYCbCr.c -o build/temp.linux-armv7l-2.7/src/libImaging/ConvertYCbCr.o
The bug is not reproducible, so it is likely a hardware or OS problem.
Followed by a bunch of lines like:
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Dib.c -o build/temp.linux-armv7l-2.7/src/libImaging/Dib.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/decode.c -o build/temp.linux-armv7l-2.7/src/decode.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Fill.c -o build/temp.linux-armv7l-2.7/src/libImaging/Fill.o
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DHAVE_LIBJPEG -DHAVE_LIBZ -DPILLOW_VERSION="5.2.0" -I/tmp/pip-install-qnvAde/Pillow/src/libImaging -I/usr/include/freetype2 -I/usr/lib/arm-linux-gnueabihf -I/home/pi/oprint/include -I/usr/local/include -I/usr/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c src/libImaging/Draw.c -o build/temp.linux-armv7l-2.7/src/libImaging/Draw.o
and then at the bottom:
arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-armv7l-2.7/src/_imaging.o build/temp.linux-armv7l-2.7/src/decode.o build/temp.linux-armv7l-2.7/src/encode.o build/temp.linux-armv7l-2.7/src/map.o build/temp.linux-armv7l-2.7/src/display.o build/temp.linux-armv7l-2.7/src/outline.o build/temp.linux-armv7l-2.7/src/path.o build/temp.linux-armv7l-2.7/src/libImaging/Access.o build/temp.linux-armv7l-2.7/src/libImaging/AlphaComposite.o build/temp.linux-armv7l-2.7/src/libImaging/Resample.o build/temp.linux-armv7l-2.7/src/libImaging/Bands.o build/temp.linux-armv7l-2.7/src/libImaging/BcnDecode.o build/temp.linux-armv7l-2.7/src/libImaging/BitDecode.o build/temp.linux-armv7l-2.7/src/libImaging/Blend.o build/temp.linux-armv7l-2.7/src/libImaging/Chops.o build/temp.linux-armv7l-2.7/src/libImaging/ColorLUT.o build/temp.linux-armv7l-2.7/src/libImaging/Convert.o build/temp.linux-armv7l-2.7/src/libImaging/ConvertYCbCr.o build/temp.linux-armv7l-2.7/src/libImaging/Copy.o build/temp.linux-armv7l-2.7/src/libImaging/Crop.o build/temp.linux-armv7l-2.7/src/libImaging/Dib.o build/temp.linux-armv7l-2.7/src/libImaging/Draw.o build/temp.linux-armv7l-2.7/src/libImaging/Effects.o build/temp.linux-armv7l-2.7/src/libImaging/EpsEncode.o build/temp.linux-armv7l-2.7/src/libImaging/File.o build/temp.linux-armv7l-2.7/src/libImaging/Fill.o build/temp.linux-armv7l-2.7/src/libImaging/Filter.o build/temp.linux-armv7l-2.7/src/libImaging/FliDecode.o build/temp.linux-armv7l-2.7/src/libImaging/Geometry.o build/temp.linux-armv7l-2.7/src/libImaging/GetBBox.o build/temp.linux-armv7l-2.7/src/libImaging/GifDecode.o build/temp.linux-armv7l-2.7/src/libImaging/GifEncode.o build/temp.linux-armv7l-2.7/src/libImaging/HexDecode.o build/temp.linux-armv7l-2.7/src/libImaging/Histo.o build/temp.linux-armv7l-2.7/src/libImaging/JpegDecode.o build/temp.linux-armv7l-2.7/src/libImaging/JpegEncode.o build/temp.linux-armv7l-2.7/src/libImaging/Matrix.o build/temp.linux-armv7l-2.7/src/libImaging/ModeFilter.o build/temp.linux-armv7l-2.7/src/libImaging/Negative.o build/temp.linux-armv7l-2.7/src/libImaging/Offset.o build/temp.linux-armv7l-2.7/src/libImaging/Pack.o build/temp.linux-armv7l-2.7/src/libImaging/PackDecode.o build/temp.linux-armv7l-2.7/src/libImaging/Palette.o build/temp.linux-armv7l-2.7/src/libImaging/Paste.o build/temp.linux-armv7l-2.7/src/libImaging/Quant.o build/temp.linux-armv7l-2.7/src/libImaging/QuantOctree.o build/temp.linux-armv7l-2.7/src/libImaging/QuantHash.o build/temp.linux-armv7l-2.7/src/libImaging/QuantHeap.o build/temp.linux-armv7l-2.7/src/libImaging/PcdDecode.o build/temp.linux-armv7l-2.7/src/libImaging/PcxDecode.o build/temp.linux-armv7l-2.7/src/libImaging/PcxEncode.o build/temp.linux-armv7l-2.7/src/libImaging/Point.o build/temp.linux-armv7l-2.7/src/libImaging/RankFilter.o build/temp.linux-armv7l-2.7/src/libImaging/RawDecode.o build/temp.linux-armv7l-2.7/src/libImaging/RawEncode.o build/temp.linux-armv7l-2.7/src/libImaging/Storage.o build/temp.linux-armv7l-2.7/src/libImaging/SgiRleDecode.o build/temp.linux-armv7l-2.7/src/libImaging/SunRleDecode.o build/temp.linux-armv7l-2.7/src/libImaging/TgaRleDecode.o build/temp.linux-armv7l-2.7/src/libImaging/TgaRleEncode.o build/temp.linux-armv7l-2.7/src/libImaging/Unpack.o build/temp.linux-armv7l-2.7/src/libImaging/UnpackYCC.o build/temp.linux-armv7l-2.7/src/libImaging/UnsharpMask.o build/temp.linux-armv7l-2.7/src/libImaging/XbmDecode.o build/temp.linux-armv7l-2.7/src/libImaging/XbmEncode.o build/temp.linux-armv7l-2.7/src/libImaging/ZipDecode.o build/temp.linux-armv7l-2.7/src/libImaging/ZipEncode.o build/temp.linux-armv7l-2.7/src/libImaging/TiffDecode.o build/temp.linux-armv7l-2.7/src/libImaging/Jpeg2KDecode.o build/temp.linux-armv7l-2.7/src/libImaging/Jpeg2KEncode.o build/temp.linux-armv7l-2.7/src/libImaging/BoxBlur.o build/temp.linux-armv7l-2.7/src/libImaging/QuantPngQuant.o build/temp.linux-armv7l-2.7/src/libImaging/codec_fd.o -L/tmp/pip-install-qnvAde/Pillow -L/home/pi/oprint/lib -L/usr/local/lib -L/usr/lib/arm-linux-gnueabihf -ljpeg -lz -o build/lib.linux-armv7l-2.7/PIL/_imaging.so
arm-linux-gnueabihf-gcc: error: build/temp.linux-armv7l-2.7/src/libImaging/Resample.o: No such file or directory
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
Command "/home/pi/oprint/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-qnvAde/Pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-nlSyl9/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/oprint/include/site/python2.7/Pillow" failed with error code 1 in /tmp/pip-install-qnvAde/Pillow/
Error!
Thanks for any help. I'm a Linux noob so I don't really speak all that "sudo" "pip", etc stuff yet.
#18
@aolshove, did you get it working?
#19
No, I just kind of gave up.
#20
@aolshove,
Have you upgraded pip? If not, try that first like so:
Then try to install Octolapse again through the plugin manager. Let me know how it goes.
