How do I get access to live video stream remotely?
#1
Hi!
I have set up a dynamic DNS adress from noip.com, so I have access to Octoprint via an adress like ***************.ddns.net
Everything works fine, exept for one thing:
As soon as I access my Octoprint from outside my home network, I can't see the live stream from my Rasberry Pi Camera anymore. (I can only see the live video stream when I access Octoprint from within my home network)
How do I set things up so I can see the live video stream from ouside my home network (via ***************.ddns.net) ?
Current video stream URL in Octoprint settings is set to: http://octopi:8080/?action=stream
My setup:
Prusa i3 MK3 with an RPi Zero W and a Raspberry Pi Camera v2.
OctoPrint version 1.3.8
Thanks for your help!
#2
#3
Thanks for a fast reply, foosel!
Now it works! :smiley:
Of course i should have read the FAQ before posting.. Lesson learned!
Have a nice day,
#4
Safest thing to do is install a VPN
PiVPN makes it easy...then only one port thru your router (UDP port 1194) is open to the internet...on the device you want to log into with you install OpenVPN client...then use the key generated from the server (an .ovpn file)
https://github.com/pivpn/pivpn <- source page
Once connected...even if you are a zillion miles away...the device looks like it's sitting inside your home network thru IP tables and internal routing of the server, giving you complete encrypted access to your home network, and access to your file shares, servers, VNC, and whatever else you have hosting inside your own LAN. (and without the proper keys...noone gets in :wink: )
#5
How do you transfer the .ovpn files to their clients? I have been searching and searching for instruction on this.
#6
nvm your link told me what I needed to know, I have to have some software like WinSCP.
#7
In the ovpns folder where you create the ovpn files run this command to make a simple file server and access via your phones web browser using your Pi's IP:8080
python -m SimpleHTTPServer 8080
#8
That’s a nice way to throw the security out of the window... It is like buying an expensive lock and the mailing yourself the key in a transparent envelope with the return address clearly shown.
#9
What I love is that clone-your-own-key kiosk at Fry's Electronics, for example. It takes your credit card (now they have your home address), asks you what kind of key you're making ("home"), then they accept your existing key and duplicate it for you within moments.
But then you've just given them the ability to clone another key later, drive to your house when you're not there and open it up.
#10
Hi octopi uses the same url entered whether you are remote or local so the remote browser is looking for the same url in your case http://octopi:8080/?action=stream this is a local only address. what you can do is port forward 8080 on your router to your pi as well and change the webcam url to something like http://***************.ddns.net:8080/?action=stream then the address will resolve both inside and outside your network as long as your router supports loopback. (which most do)
#11
Doesn't octopi come pre-configured to reverse proxy the connection if you use the url like below? Seems to work that way on my install...
http://<public ip/dns name>/webcam/?action=stream
#12
Better yet, use a relative URL:
