Is there a way to make Octoprint's interface in Chrome bigger, to make it use the full width of my screen ?
See this image to understand what I mean https://imgur.com/kGTVehk
Not without re-writing your own interface via plugin and the UIPlugin mixin. You may be able to tweak some stuff with Themeify Plugin, but I don't think I've seen anyone do this yet. @OutsourcedGuru is one of the guys that has worked with that plugin a lot, so he might know.
Thanks for the answer, I thought it was something simple. I guess I'll just use the browser's zooming feature.
It's easy with Themeify, as suggested. You're looking for .span8
and .container
. Set them to numbers you find pleasing on your resolution.
I'm also using it to set the temperature graph's background image to a second Pi mjpg-streamer
here as seen from a bird's eye view. And I'm styling the custom buttons I added to the bottom of the Control tab so that the page doesn't "go long".
I'm running a fork of Themify, not that it matters.
Thank you ! This is exactly what I was looking for, I'll give it try tonight.
Me too Thank you!
I can't get it change size? am i missing something?
You may have to press Crtl F5
to clear the cache...
problem solved I had "Width" instead of "width"
Thank you for this.
I am completely new to Octoprint and am trying to get Ocotoprint's interface bigger in a browser.
Where do I set up the settings from your 2nd screenshot?
I can't seem to see a similar screen on my stock setup.
These are what my settings look like.
Thanks in advance.
Hi @dartec!
They are set in Custom Style
. You may have to play a bit with the values to fit your needs.
Thanks for the sharing
You would need to add the two lines for:
You will find this by clicking the Advanced link that is in Themeify's Settings page.
The Themeify Plugin is absolutely great! And for those of you looking to max out on the functionality, I've come across a sweet way to access all the possible containers to edit.
I use Chrome for all my browsing and it has a nice feature; the console. Press F12 on any page to bring it up and under the Elements tab, you can freely browse all of the elements of the page you're viewing. Hovering over each "<div " highlights the corresponding area on the page so you know exactly which div is for which part of the page. Following down the hierarchy will lead you to the place you want to edit.
For me, I wanted to make the list of "Files" be longer so that I could see more of them at once. For this, I added the following two styles:
.slimScrollDiv | height | 750px
.gcode_files | height | 750px
Hope this little gem helps some of you out there.
I added ".scroll-wrapper | height | 750px" and it seems to work.
This is great.
Is there any way to use the original labels (words) instead of icons in the tabbed nav on top of the graph?
There's options in themeify for icons, I think you just turn them off.
I unchecked the box under "Action" but it didn't change anything at all.
Maybe a screenshot would help me understand what the issue is you're explaining and your themeify settings. Might be able to provide more assistance. Also forcing a refresh of your browser wouldn't hurt (shift+f5 in chrome while on the page).
