Wifi on OctoPi 0.15 (pi 3)
#1
I use the image and all seem to work fine, I can access the pi via the web page, even have a webcam working, and can print, if I connect the ethernet cable, however the wifi seem to partly working. I followed the howto on Getting your WiFi Connection Working
I edited the three lines in octopi-wpa-supplicant.txt
## WPA/WPA2 secured
network={
  ssid="HUAWEI-B539-D9D0"
  psk="12345"   ## my password
country=ZA # South Africa
I double checked the spelling is correct and verified it on the pi with mcedit and did not found any strange characters.
if I run iwlist wlan0 scan , all the available Wifi's are detected an the above ssid is in the list, but if I removed the ethernet no comms at all. With the ethernet cable I can ping google, install 'mc' etc.
I did however made some changes to /etc/dhcpd.conf ti use a static IP address, un-commented three lines
  1. interface eth0
  2. static ipaddress 192.168.2.31
  3. static routers 192.168.2.10
I tried to connect with
iwconfig wlan0 essid "HUAWEI-B539-D9D0" and
iwconfig wlan0 display extra info including "HUAWEI-B539-D9D0" , however wlan0 does not have an IP address.
What am I missing ?
Wifi . octopi on pi3
#2
SSH into your Pi
Make the correct changes in options 2 and 4 (make sure you answer as many questions in option 4 as you can)
Reboot
Theoretically, that should be the end of it since you've already done the wpa-supplicant
#3
Thanks, I ssh quit a few times but have no clue what options 2 and 4 is. Do I have to run a command via the console and then select the options?
Rats. I'm sorry
I forgot to tell you to type sudo raspi-config when you are in SSH
Sorry
#5
I read that wifi setup in raspi-config would counter act with octopi, is that true of false ?
Gerrie
#6
Ok I did it and the connection works now, thanks ..
Kind Regards
Gerrie
#7
Yer welcome. Again, I apologize for leaving out the critical bit in the instructions :oops:
As to counter acting. Not exactly. When you edit raspi-config, it makes changes in wpa-supplicant. but, you still need to do them both
Happy printing !
