The 'pip' command could not be found or does not correctly work for this installation of OctoPrint
The pip command could not be found or does not work correctly for this installation of OctoPrint - please consult the log file for details and if necessary configure it manually. No installation and uninstallation of plugin packages is possible while pip is unavailable.
i have tried running pip install --upgrade within the venv and it does seem to say that pip is updated and installed, i suspect it's a user permission issue though I'm not 100% familar with linux environments.
running on Debian 9, standard octoprint installation following the raspbian instructions.
I have attached the log below
2018-10-08 17:31:33,109 - octoprint.startup - INFO - ******************************************************************************
2018-10-08 17:31:33,110 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-10-08 17:31:33,111 - octoprint.startup - INFO - ******************************************************************************
2018-10-08 17:31:33,695 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2018-10-08 17:31:34,290 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-10-08 17:31:34,762 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2018-10-08 17:31:34,767 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-10-08 17:31:34,825 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-10-08 17:31:34,858 - octoprint.server - INFO - Intermediary server started
2018-10-08 17:31:34,859 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2018-10-08 17:31:34,865 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-10-08 17:31:35,161 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-10-08 17:31:35,162 - octoprint.printer.profile - ERROR - Profile _default does not exist, creating _default again and setting it as default
2018-10-08 17:31:35,216 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/octoprint/.octoprint/uploads...
2018-10-08 17:31:35,217 - octoprint.filemanager.storage - INFO - ... file metadata for /home/octoprint/.octoprint/uploads initialized successfully.
2018-10-08 17:31:36,069 - octoprint.util.pip - INFO - Using "/home/octoprint/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2018-10-08 17:31:36,797 - octoprint.util.pip - INFO - Version of pip is 18.1
2018-10-08 17:31:36,798 - octoprint.util.pip - INFO - pip installs to /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages (writable -> no), --user flag needed -> no, virtual env -> yes
2018-10-08 17:31:36,799 - octoprint.util.pip - INFO - ==> pip ok -> NO!
2018-10-08 17:31:36,799 - octoprint.util.pip - ERROR - Cannot use this pip install, can't write to the install dir and also can't use --user for installing. Check your setup and the permissions on /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages.
2018-10-08 17:31:36,802 - octoprint.plugin.core - INFO - Initialized 10 plugin implementation(s)
2018-10-08 17:31:36,834 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
| Action Command Prompt Support (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/announcements
| Core Wizard (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/corewizard
| CuraEngine (<= 15.04) (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/cura
| Discovery (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/discovery
| Logging (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/logging
| Plugin Manager (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| Printer Safety Check (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
| Software Update (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2018-10-08 17:31:36,843 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 2
| freq: 2415.7
| ram: 4016287744
| os:
| platform: linux2
| python:
| pip: '18.1'
| version: 2.7.13
| virtualenv: /home/octoprint/OctoPrint/venv
2018-10-08 17:31:36,848 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/webassets...
2018-10-08 17:31:36,849 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/.webassets-cache...
2018-10-08 17:31:36,971 - octoprint.server - INFO - Shutting down intermediary server...
2018-10-08 17:31:37,362 - octoprint.server - INFO - Intermediary server shut down
2018-10-08 17:31:37,370 - octoprint.events - INFO - Processing startup event, this is our first event
2018-10-08 17:31:37,371 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2018-10-08 17:31:37,374 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-10-08 17:31:37,378 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-10-08 17:31:37,382 - octoprint.plugins.cura - INFO - Path to CuraEngine has not been configured or does not exist (currently set to None), Cura will not be selectable for slicing
2018-10-08 17:31:37,388 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on fsaeoctoprint for SSDP
2018-10-08 17:31:37,391 - octoprint.server - INFO - Listening on ://[::]:5000
2018-10-08 17:31:38,806 - octoprint.plugins.announcements - INFO - Loaded channel _important from s://octoprint.org/feeds/important.xml in 1.4s
2018-10-08 17:31:39,165 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from s://plugins.octoprint.org/plugins.json
2018-10-08 17:31:39,697 - octoprint.util.pip - INFO - Using "/home/octoprint/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2018-10-08 17:31:40,468 - octoprint.plugins.announcements - INFO - Loaded channel _releases from s://octoprint.org/feeds/releases.xml in 1.5s
2018-10-08 17:31:40,890 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from s://plugins.octoprint.org/notices.json
2018-10-08 17:31:42,075 - octoprint.plugins.announcements - INFO - Loaded channel _blog from s://octoprint.org/feeds/octoblog.xml in 1.6s
2018-10-08 17:31:42,124 - octoprint.util.pip - INFO - pip installs to /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/ (writable -> no), --user flag needed -> no, virtual env -> yes
2018-10-08 17:31:42,124 - octoprint.util.pip - INFO - ==> pip ok -> NO!
2018-10-08 17:31:42,125 - octoprint.util.pip - ERROR - Cannot use this pip install, can't write to the install dir and also can't use --user for installing. Check your setup and the permissions on /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/.
2018-10-08 17:31:42,139 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-10-08 17:31:43,712 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from s://plugins.octoprint.org/feed.xml in 1.6s
2018-10-08 17:31:45,282 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from s://octoprint.org/feeds/octopi.xml in 1.5s
2018-10-08 17:34:57,997 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': 'l10n=en', 'path': u'/', '_count': 1, '_timestamp': 1538982297.997526, 'base_url': '://localhost:5000/'}
2018-10-08 17:35:07,805 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-10-08 17:36:13,183 - tornado.access - WARNING - 404 GET /webcam/?action=stream (::1) 12.00ms
2018-10-08 17:38:26,647 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
2018-10-08 17:38:31,054 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-10-08 17:40:41,759 - octoprint.server - INFO - Shutting down...
2018-10-08 17:40:42,598 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2018-10-08 17:40:42,607 - octoprint.events - INFO - Event loop shut down
2018-10-08 17:40:42,610 - octoprint.server - INFO - Goodbye!
2018-10-08 17:47:20,172 - octoprint.startup - INFO - ******************************************************************************
2018-10-08 17:47:20,174 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-10-08 17:47:20,174 - octoprint.startup - INFO - ******************************************************************************
2018-10-08 17:47:20,741 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-10-08 17:47:24,175 - octoprint.startup - INFO - Blacklist processing done
2018-10-08 17:47:24,198 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2018-10-08 17:47:24,661 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-10-08 17:47:25,133 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2018-10-08 17:47:25,139 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-10-08 17:47:25,196 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-10-08 17:47:25,219 - octoprint.server - INFO - Intermediary server started
2018-10-08 17:47:25,220 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2018-10-08 17:47:25,225 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-10-08 17:47:25,536 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-10-08 17:47:25,557 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/octoprint/.octoprint/uploads...
2018-10-08 17:47:25,558 - octoprint.filemanager.storage - INFO - ... file metadata for /home/octoprint/.octoprint/uploads initialized successfully.
2018-10-08 17:47:25,579 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2018-10-08 17:47:26,358 - octoprint.util.pip - INFO - Using "/home/octoprint/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2018-10-08 17:47:27,132 - octoprint.util.pip - INFO - Version of pip is 18.1
2018-10-08 17:47:27,133 - octoprint.util.pip - INFO - pip installs to /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages (writable -> no), --user flag needed -> no, virtual env -> yes
2018-10-08 17:47:27,134 - octoprint.util.pip - INFO - ==> pip ok -> NO!
2018-10-08 17:47:27,135 - octoprint.util.pip - ERROR - Cannot use this pip install, can't write to the install dir and also can't use --user for installing. Check your setup and the permissions on /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages.
2018-10-08 17:47:27,137 - octoprint.plugin.core - INFO - Initialized 10 plugin implementation(s)
2018-10-08 17:47:27,142 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
2018-10-08 17:47:27,153 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 2
| freq: 2415.7
| ram: 4016287744
| os:
| platform: linux2
| python:
| pip: '18.1'
| version: 2.7.13
2018-10-08 17:47:27,160 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/webassets...
2018-10-08 17:47:27,173 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/.webassets-cache...
2018-10-08 17:47:27,271 - octoprint.server - INFO - Shutting down intermediary server...
2018-10-08 17:47:27,724 - octoprint.server - INFO - Intermediary server shut down
2018-10-08 17:47:27,732 - octoprint.events - INFO - Processing startup event, this is our first event
2018-10-08 17:47:27,733 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2018-10-08 17:47:27,737 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-10-08 17:47:27,738 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-10-08 17:47:27,773 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-10-08 17:47:27,972 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-10-08 17:47:28,125 - octoprint.plugins.cura - INFO - Path to CuraEngine has not been configured or does not exist (currently set to None), Cura will not be selectable for slicing
2018-10-08 17:47:28,175 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on fsaeoctoprint for SSDP
2018-10-08 17:47:28,176 - octoprint.server - INFO - Listening on ://[::]:5000
2018-10-08 17:47:28,251 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-10-08 17:47:28,344 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': '://localhost:5000/'}
2018-10-08 17:47:28,491 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-10-08 17:47:33,921 - octoprint.server.preemptive_cache - INFO - ... done in 5.58s
2018-10-08 17:47:38,780 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-10-08 17:47:40,159 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
2018-10-08 17:47:44,484 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-10-08 17:47:59,735 - octoprint.utilm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-10-08 17:47:59,747 - octoprint.utilm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2018-10-08 17:47:59,759 - octoprint.utilm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2018-10-08 17:48:00,768 - octoprint.utilm - INFO - M110 detected, setting current line number to 0
2018-10-08 17:48:00,874 - octoprint.utilm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2018-10-08 17:48:00,884 - octoprint.utilm - INFO - M110 detected, setting current line number to 0
2018-10-08 17:48:02,987 - octoprint.utilm - INFO - Printer seems to support the busy protocol, telling it to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2018-10-08 17:48:09,531 - octoprint.utilm - INFO - Got a resend request for line 1 which is also our current line. It looks like we just handled a reset and this is a left over of this
2018-10-08 17:48:09,558 - octoprint.utilm - INFO - Printer reports firmware name "Prusa-Firmware 3.4.1 based on Marlin"
2018-10-08 17:48:15,799 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
2018-10-08 17:48:15,926 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-10-08 17:49:50,330 - octoprint.server - INFO - Shutting down...
2018-10-08 17:49:51,189 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2018-10-08 17:49:51,193 - octoprint.events - INFO - Event loop shut down
2018-10-08 17:49:51,210 - octoprint.server - INFO - Goodbye!
2018-10-08 17:49:59,711 - octoprint.startup - INFO - ******************************************************************************
2018-10-08 17:49:59,712 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-10-08 17:49:59,713 - octoprint.startup - INFO - ******************************************************************************
2018-10-08 17:50:00,307 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-10-08 17:50:00,313 - octoprint.startup - INFO - Blacklist processing done
2018-10-08 17:50:00,344 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2018-10-08 17:50:00,860 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-10-08 17:50:01,340 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2018-10-08 17:50:01,346 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-10-08 17:50:01,406 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-10-08 17:50:01,428 - octoprint.server - INFO - Intermediary server started
2018-10-08 17:50:01,428 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2018-10-08 17:50:01,434 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-10-08 17:50:01,745 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-10-08 17:50:01,768 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/octoprint/.octoprint/uploads...
2018-10-08 17:50:01,769 - octoprint.filemanager.storage - INFO - ... file metadata for /home/octoprint/.octoprint/uploads initialized successfully.
2018-10-08 17:50:01,793 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2018-10-08 17:50:02,532 - octoprint.util.pip - INFO - Using "/home/octoprint/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2018-10-08 17:50:03,330 - octoprint.util.pip - INFO - Version of pip is 18.1
2018-10-08 17:50:03,332 - octoprint.util.pip - INFO - pip installs to /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages (writable -> no), --user flag needed -> no, virtual env -> yes
2018-10-08 17:50:03,332 - octoprint.util.pip - INFO - ==> pip ok -> NO!
2018-10-08 17:50:03,333 - octoprint.util.pip - ERROR - Cannot use this pip install, can't write to the install dir and also can't use --user for installing. Check your setup and the permissions on /home/octoprint/OctoPrint/venv/lib/python2.7/site-packages.
2018-10-08 17:50:03,336 - octoprint.plugin.core - INFO - Initialized 10 plugin implementation(s)
2018-10-08 17:50:03,341 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
2018-10-08 17:50:03,352 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 2
| freq: 2415.7
| ram: 4016287744
| os:
| platform: linux2
| python:
| pip: '18.1'
| version: 2.7.13
2018-10-08 17:50:03,358 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/webassets...
2018-10-08 17:50:03,371 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/.webassets-cache...
2018-10-08 17:50:03,472 - octoprint.server - INFO - Shutting down intermediary server...
2018-10-08 17:50:03,933 - octoprint.server - INFO - Intermediary server shut down
2018-10-08 17:50:03,937 - octoprint.events - INFO - Processing startup event, this is our first event
2018-10-08 17:50:03,940 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2018-10-08 17:50:03,945 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-10-08 17:50:03,949 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-10-08 17:50:03,984 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-10-08 17:50:04,174 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-10-08 17:50:04,270 - octoprint.plugins.cura - INFO - Path to CuraEngine has not been configured or does not exist (currently set to None), Cura will not be selectable for slicing
2018-10-08 17:50:04,363 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on fsaeoctoprint for SSDP
2018-10-08 17:50:04,369 - octoprint.server - INFO - Listening on ://[::]:5000
2018-10-08 17:50:04,431 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-10-08 17:50:04,639 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': '://localhost:5000/'}
2018-10-08 17:50:04,809 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-10-08 17:50:06,805 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-10-08 17:50:10,484 - octoprint.server.preemptive_cache - INFO - ... done in 5.85s
2018-10-08 17:50:21,112 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
2018-10-08 17:50:22,830 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-10-08 17:50:45,025 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from s://plugins.octoprint.org/plugins.json
2018-10-08 17:50:47,108 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from s://plugins.octoprint.org/notices.json
2018-10-08 17:50:55,629 - octoprint.server - INFO - Shutting down...
2018-10-08 17:50:56,288 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2018-10-08 17:50:56,299 - octoprint.events - INFO - Event loop shut down
2018-10-08 17:50:56,302 - octoprint.server - INFO - Goodbye!
2018-10-08 17:54:56,675 - octoprint.startup - INFO -
I have also removed http because the forum was complaining about links.
this seems to be the issue however i don't know how to resolve it.
Have you installed OctoPrint via OctoPi or onto an existing https://discourse.octoprint.org/t/setting-up-octoprint-on-a-raspberry-pi-running-raspbian/2337 installation?
this isn't running on a rpi, it's running on an standard PC, thus running normal debian 9.
followed the standard raspbian installation procedure as raspian is based on debian.
octoprint@fsaeoctoprint:~$ ls -ld OctoPrint/venv/lib/python2.7/site-packages/
drwxr-xr-x 126 root root 4096 Oct  8 14:39 OctoPrint/venv/lib/python2.7/site-packages/
octoprint@fsaeoctoprint:~$ id
uid=1000(octoprint) gid=1000(octoprint) groups=1000(octoprint),5(tty),20(dialout),24(cdrom),25(floppy),29(audio),30(dip),44(video),46(plugdev),108(netdev),114(bluetooth),115(lpadmin),119(scanner)
octoprint@fsaeoctoprint:~$ ps -ef | grep -i octoprint
avahi      320     1  0 17:51 ?        00:00:00 avahi-daemon: running [fsaeoctoprint.local]
octopri+  1098   949  1 17:54 pts/0    00:01:17 /home/octoprint/OctoPrint/venv/bin/python2 venv/bin/octoprint serve
octopri+  1158     1  0 17:56 ?        00:00:00 /usr/lib/libreoffice/program/oosplash --writer file:///tmp/mozilla_octoprint0/octoprint.log
octopri+  1175  1158  0 17:56 ?        00:00:17 /usr/lib/libreoffice/program/soffice.bin --writer file:///tmp/mozilla_octoprint0/octoprint.log --splash-pipe=5
octopri+  1743  1453  0 19:08 pts/2    00:00:00 grep -i octoprint
i suspect it's a user permission issue.
though i don't unfortunately know enough to diagnose.
fixed the problem doing a
chown -R on the octoprint folder.
for future reference the python folder was owned by root, thus the normal user couldn't access pip.
...noting of course that Raspbian out-of-the-box has the pi user setup already and Debian does not.
even i was facing the same issue.
open plugin manager
there is a wrench icon on the top right hand side.
click on it
there is a option for pip configuratation
slection forece the use and save
tehn re fresh
you will get the updates
Sorry to resurect an old thread like this, but I had some trouble with my Octoprint and did a clean install. I got the 1,3,12 version and I have the pip error. Problem is, I know very little about coding and don't know hot to do a chown -R as it says. Please help me!
Log
2019-09-26 01:29:54,945 /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/jneilliii/OctoPrint-BedLevelVisualizer/archive/master.zip --no-cache-dir
2019-09-26 01:29:57,381 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2019-09-26 01:29:57,382 > Collecting https://github.com/jneilliii/OctoPrint-BedLevelVisualizer/archive/master.zip
2019-09-26 01:29:57,884 ! WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),)': /jneilliii/OctoPrint-BedLevelVisualizer/archive/master.zip
2019-09-26 01:29:58,886 ! WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),)': /jneilliii/OctoPrint-BedLevelVisualizer/archive/master.zip
2019-09-26 01:29:59,889 ! WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),)': /jneilliii/OctoPrint-BedLevelVisualizer/archive/master.zip
2019-09-26 01:30:02,016 ! WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),)': /jneilliii/OctoPrint-BedLevelVisualizer/archive/master.zip
2019-09-26 01:30:06,448 ! WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),)': /jneilliii/OctoPrint-BedLevelVisualizer/archive/master.zip
2019-09-26 01:30:06,448 ! ERROR: Could not install packages due to an EnvironmentError: HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /jneilliii/OctoPrint-BedLevelVisualizer/archive/master.zip (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
This is an unrelated problem to the original thread, since yours is network related. Please open a new thread, and fill in the entire template so we can help you better.
Thanks that fixed it for me.
