Set Feed Rate and Flow Rate
It would be nice if I could set Feed Rate and Flow Rate myself
Use the feedrate/flowrate overrides:
Or the terminal:
Or just add a custom control
Yes, I know but override is limited by 150% / 125% and yes I can use the terminal to set the value but when override is there I think it would be better to put the value there instead of%
That's why I also linked you to the custom controls. Just add whatever you are missing through your local config.
sorry i did not see that:sleeping:
thank you
