Selecting problem in FilamentManager
Hi there.
Related to this: FilamentManager
From settings i have selected: "Show dialog to confirm selected spools before starting/resuming the print job" option.
Many times i don't get my spool collection popup, therefore can't print.
See this: https://www.youtube.com/watch?v=6eOClE6aVOo
I had spool selected, usually i have to do that many times, before spool selection comes for popup, this was first time when it was so easy.
What i'm doing wrong?
BR, Jere
https://github.com/malnvenshorn/OctoPrint-FilamentManager/issues/73#issuecomment-360411225
Is this relevant to you? Looks like it's an issue where you try to start a print before the file has been analysed / some weird bug means the info about the file never gets updated.
Yep, looks like same.
another thing... i had this problem yeasterday
i ran out of filament during the last minute of printing
i have looked at a runout sensor so print could be paused and me could then get a new spool ready
but i cant figure if this is supported or is planned to be
of course the pause would also mean that the nozzle has to be parked in a good spot as not to ruin the print
the plugin should also ask if this is just a new spool of the one that is used up etc so it could reset the amount used
@jesi Did you used 'print' or 'load and print'? Was the file analysed before the dialog was opened? It doesn't work when the filament data is not available.
@boelle There are plugins available for hardware filament sensors. The filament manager tries to do the same thing in software if the feature has been enabled.
Seee https://github.com/malnvenshorn/OctoPrint-FilamentManager/issues/73.
I think I just found why people run into this issue as I did.
It's more a matter of not understanding and using the plugin correctly and the user interface being a little confusing, especially when not used that frequently. I've added a suggestion for improvement as wel.
