PSA: Please mark the solutions to your topics as such
All topics you create in this category can be marked as "Solved" by clicking the little :marksolved: icon under the post that contains the solution:
Please make heavy use of it. Marking a topic as solved allows others to quickly see that a solution has been found and also displays the solution prominently right in the start post so that others with the same problem may find it easier, without having to scan through the whole thread.
Thank you!
