Problem with NavBar Temp ? Not really
I had a problem with my NavBar temp plugin. It was handy to see that info posted right at the top where I could see it
Suddenly, it vanished. Poof
I uninstalled, reinstalled, turned off, turned on, checked settings.
Nothing seemed to help, until, I tried something stoopid on a hunch (I do both of those a lot, something stoopid, and follow hunches)
I swiped my mouse along the NavBar, thus highliting anything in it, and guess what ? There it was, just being printed in the same colour as the NavBar itself
All I needed to do was change the colours, and everything was right with the world again
Now, where's the solved button ?
How'd you change them? Do you mean you edited the plugin's css or you used something like the Themeify plugin to alter the colours? Does the plugin author know it wasn't rendering correctly?
Well, it was two plugins. Navbar temp put the temps up there, then I installed themeify, and it changed the colors of the navbar
Just something that I thought people should be aware of
Well, it was two plugins both doing the same thing. Navbar temp put the temps up there, then I installed themeify, and it changed the colors of the navbar
