Print stops randomly
Hey everyone I have a problem ^^
I tried twice to print a "long print" (~24h), printed from the raspberry pi and not the SD card. First time it stopped not far from 50% and the second one about 90% (for the second attempt it started around 18:00 yesterday and it stopped around 14:00 this afternoon)
Nothing because i don't have a clue what to do.
OctoPrint version : 1.3.9
OctoPi version : 0.15.1
tevo tornado runing marlin 1.1.9
octoprint.log.zip (3.4 KB)
Thank you in advance for your time
Have you reviewed the log? It seems to have many error messages from both the Anywhere plugin and its backoff dependency.
Try running in Safe Mode and compare. If that's happy, return to standard mode and disable OctoPrint-Anywhere.
I had issues related to the Anywhere plugin a while back. Make sure you have the latest version. Also the Dev is very responsive. Hit him up and have him look at your logs.
