Print issue only with octoprint
Hey,
the problem is that if I start a print over octoprint it randomly stops/starts to print the same line all over.
At first I thought it is a problem with the TMC2208 Motor Driver, but then the problem appears all the time and not just with octoprint.
Reduce Baud to 11500
Update
Marlin 1.1.8
OrangePi Zero
Armbian 5.6
VertexK8400 with MKS GenL Motherboard
Cura 3.6.0
octoprint.log (50.8 KB)
serial.log was not activated.
Hope you can help me find the problem :slight_smile:
Hi @LuckyLuzz
  1. I can't access the images in your link...
  2. In this case, a serial.log is most helpful. Please try to reproduce this issue with active serial logging.
serial.log (2.5 MB)
Hey,
I was "lucky" that it happened while I was watching, the log looks normal. Any suguestions?
