Pip version warning after successful plugin installation
After installing plugins getting warning about outdated pip version.
Run apt-get update/upgrade and have all the latest updates installed.
OctoPrint 1.3.10 running on OctoPi 0.15.1
Printer: Velleman Vertex K8400 converted into H-bot
Firmware: Klipper
Yesterday I discovered this video https://www.youtube.com/watch?v=Zq1sFBgxy8o by Teaching Tech and decided to install several plugins mentioned in this clip. While I did not have any issues with installation process itself, at the very end of installing each plugin I was getting the message
You are using pip version 9.0.3, however version 18.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
So, my question is - should I run the command
/home/pi/oprint/bin/python2 -m pip install https://github.com/malnvenshorn/OctoPrint-WebcamTab/archive/master.zip --no-cache-dir
as mentioned in plugin_pluginmanager_console.log, should I run any other command or just ignore this warning?
Best regards,
Boris
octoprint.log (372.8 KB)
serial.log (6.5 KB)
plugin_pluginmanager_console.log (122.8 KB)
Don't worry about this warning. PIP version 9 works just fine for OctoPrint.
@fieldOfView Thanks! Good to know.
@foosel You might consider adding the flag for pip install so that it stops doing this. I've seen a number of people taking it on their own to attempt to upgrade pip due to this message.
pip list --disable-pip-version-check
And again, today, we have another user trying to upgrade their pip.
