Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2417)
After Update from OctoPi 0.15.0. OctoPrint 1.3.8 shows this error missage:
and do not connect to my Prusa i3 Mk3 using EINSY RPi Port connected to Raspberry GPIO using /dev/ttyAMA0.
This config works fine with OctoPi 0.14.0.
I have tested using the USB (/dev/ttyACM0) on Raspberry and the USB Port on the EINSY, and with this cable, OctoPi connects to EINSY board.
OctoPi 0.15.0
OctoPrint 1.3.8
Printer Prusa i3 Mk3
PrintBoard EINSY
Firmware 3.1.3-RC1-243 prusa3d.com
Thanks.
I have the same problem with the same version. It's my first installation, so I don't know if another version works. I'm trying to talk to Marlin on RAMPS
Using:
OctoPi 0.14.0
OctoPrint 1.3.6
Works fine.
I have returned to these versions.
I got it! You need to use /dev/ttyUSB0 as your serial port.
0.14 will not work with PI 3+ model B
@Christian_Weller OctoPi 0.15.0 is the minimum version for an RPi 3B+. There's a few threads here on the RPi 3B+ that might be worth reading, which I'll link below :slight_smile: There's also an OctoPi 0.15.1 RC available right now that could use some more people testing it, and that should be pretty snazzy on a 3B+.
@supertaz thank you. I can connect to the Arduino now (it stops because the BLTouch is not connected and throws an error), later I will test connecting to the printer and see if I can start doing basic tasks. Sure, an RC is very attractive, but I have never used and explored Octoprint yet. As soon as I get familiar with it and do a few prints, I will be happy to do some beta testing.
No worries. I was more saying that, if you have issues, the RC has the latest stuff to work with the 3B+, in the event that @guysoft fixed something that is giving you a headache with the 0.15 release. :slight_smile: I don't have a 3B+, so I can't speak to what may be headache evoking :wink:
@supertaz it's always a dilemma with the new stuff, so I'm really lucky/glad a 3B+ compatible version is already available. In fact, if I want to find an RPI in a brick and mortar store where I live (it's really easy to get a fake sold), I only have one choice, and they only have the newest version.
LOL usually it's a case of overpriced, outdated hardware being all you can find...you've got the bleeding edge problem. If I didn't have a bunch of SBCs around, I'd probably buy a 3B+, but I honestly have enough 3Bs and other SBCs to handle what I need at present. I'm sure that'll eventually change, though. Ironically, I bought about 3 of the 3Bs right before they announced the 3B+. :man_facepalming:
Aww, that's too bad LOL
Happened to others, too...they didn't tell anyone it was on the horizon. It's okay, though...I also bought a Libre at the same time that has a faster processor on it that's 64-bit. It's going to be used for part of a vision system that needs way more horsepower than the RPi can provide. If it's successful, I may get more of them for other vision system components. None of this is related to OctoPrint, though I could imagine one of the Libres would probably provide a lot of head room for OctoPrint, even with 2 cameras on it.
Ok, I'm an idiot. I can't find 0.14 for download. Do I have to build form scratch? I'm hoping that I'm just being dense not being able to find it.
Thanks in advance
@pimin Shouldn't you be using the latest version...?
I have an RPi3B (not +). I'm seeing the readline error. It was pointed out that 0.15 has this problem on B models. So I don't think so but, I could be wrong.
Supertaz suggested that 0.15.0 is the minimal version you'd need for the 3B+. And just above, you asked how to get the earlier 0.14.0.
I personally have a Raspberry Pi 3B (no plus) and I'm running the latest. There's no problem on this Raspi for any version that I'm aware of.
I have an RPi 3B. Well into a large print, I see this error:
Offline (Error: SerialException: 'device reports readiness to read but returned no data
(device disconnected or multiple access on port?)' @ comm.py:_readline:2581)
Sebastian suggested he had returned to
OctoPi 0.14.0
OctoPrint 1.3.6
and his setup was running fine. Is there an archive of previous Octopi somewhere? Or do I have to git the source and install from scratch? A downloadable archive would be great but, I can build from scratch if I have too.
TIA
I'm guessing that this is what you're looking for.
Looks promising.
Lower baud rates just take longer to get to the error.
