Well, something else is still messed up, I can't get the MG Setup to load.
How do I refresh/reload Octopi on the Pi?
I am using the Pi and software that came with my MakerGear printer. If I install a new image like this will it work the same way or do I need some customization?
Thanks,
Will
That is probably a question you should be asking MakerGear, I don't know in what way they've modified the stuff they ship with their printers.
I occasionally notice very high ram usage and have to close and reopen the tab. This seems to happen more if the tabs been open for a while
I received a new SD card image from Makergear a couple of days ago. It comes with Octoprint 1.3.6 installed. After making a backup of it, I installed the card in the Pi and restarted the system. After configuring it using the temporary wifi access point, I restarted the Pi and went to the Octopi web page. Once again it started using 100% CPU (on a dual core E8400).
I did some more testing with this version. I discovered that if I turn off either the Makergear plugin or the Software Update plugin, the cpu usage goes to normal. What's really odd is that turning off Software Update also removed the Makergear setup tab and the Makergear settings. I do not understand why but that's probably why turning off Software Update gets rid of the cpu usage problem, because somehow it's also disabling the Makergear plugin. I have opened up an incident on the Maker Gear support system.
I also downloaded the Octopi SD Card image and restored that to a spare micro SD card. The first challenge was getting it to enable the serial port on the Pi 3. I managed to figure out at least a part of that (wasted a few hours on that!). Then I installed the Makergear Plugin, and it was back to chewing up the CPU on my PC again...
I also discovered that with this version of Octoprint (1.3.9) I cannot make changes to the "Intervals & Timeouts" settings - if I change any values on that page, the "Save" button no longer works...
William
William
Known bug, to be fixed in 1.3.10.
I'd also just like to point out that my initial diagnosis after the observed behaviour in safe mode (= no issue) that some third party plugin is at fault here was right. And now everyone reading this hopefully knows why I keep on insisting running in safe mode to rule out misbehaving third party plugins - it can save a tremendous amount of analysis time.
FWIW - I enabled the Java console and discovered why disabling the Software Update plugin stopped the CPU usage problem. Apparently the MakerGear plugin has a dependency on the Software Update plugin. This is from the Java console:
Could not instantiate the following view models due to unresolvable dependencies: packed_core.js:13173:21
mGSetupViewModel (missing: softwareUpdateViewModel ) packed_core.js:13175:25
... dependency resolution done packed_core.js:13184:9
Still working with MakerGear to try to resolve this problem.
That's what I meant with
JavaScript Java is a completely different language and these days not really installed in browsers any more.
