Octopi 0.15 and running 2 printers with one Raspberry pi
#1
I am wanting to run my two Ender2 printers with just one Raspberry Pi. I have found guides on how to set this up (basically running two instances of OctoPrint), but they are for older versions of Octopi. I am curious if anything has changed with Octopi 0.15 from previous versions that might change how this would be set up.
Thank you for any help.
#2
The changes of OctoPrint are not that much that these "old" guides should not work.
And, btw.
#3
Thanks for the help. I know the way you add your SSID and password are new in the newer version, plus you have to add your country in as well. I am assuming that once you get OctoPrint up and running, you then create the 2nd instance of it to run on your other printer?
#4
It should.
To be honest, I've done myself the luxury with another RasPi for my second printer.
#5
To me, running two printers from one Raspberry Pi feels about as risky as...
Printer(s) hang mid print
