New release candidate: 1.3.9rc3
#1
This third release candidate of the 1.3.9 release fixes two regressions and adds some resilience against specific resend and timeout scenarios during an ongoing job_on_hold lock (as used e.g. by Octolapse):
  • #2677 (regression) - Fix a deadlock when job_on_hold is utilized (causing issues at least with Octolapse)
  • #2719 (regression) - Fix live print time estimation
  • Fix resend and timeout handling during an active job_on_hold.
You can find the full changelog and release notes as usual on Github.
If you are tracking the “Maintenance RC” release channel, you should soon get an update notification just like you are used to from stable releases.
If you want to help test this release candidate and aren’t yet tracking the “Maintenance RCs” release channel, you can find information on how to switch in this guide (also linked below).
If you are not interested in helping to test release candidates, just ignore this post, 1.3.9 stable will hit your instance via the usual way once reports indicate that it’s ready 😊
Please provide feedback on this RC. For general feedback you can use this ticket on the tracker. The information that everything works fine for you is also valuable feedback 😄 For bug reports please follow “How to file a bug report”.
Depending on how the feedback for this release candidate turns out, I’ll either look into releasing 1.3.9 or fix any observed regressions and push out a new release candidate ASAP.
Links
This is a companion discussion topic for the original entry at https://octoprint.org/blog/2018/07/16/new-release-candidate-1.3.9rc3/
