Looking for an ajax example
I am trying to implement functionality where the plugin's settings javascript code calls back to the plugin's server code.
I am having trouble locating such an example. Is this possible?
Definitely. But you'll have to create your own settings view model and bind that to your settings pane. Then to e.g. query a SimpleApi endpoint provided by your plugin you'd do something like this:
OctoPrint.simpleApiGet("my_plugin")
    .done(function(response) {
        // do something with the response
or to send a comment to a SimpleApi:
var  payload = {"parameter": "value", "other_parameter": "other_value"};
OctoPrint.simpleApiCommand("my_plugin", "my_command", payload)
or to query some Blueprint endpoint:
OctoPrint.get(OctoPrint.getBlueprintUrl("my_plugin") + "my_endpoint")
See also the JS client library documentation.
@foosel Thank you. How do I define the method on the server-side (e.g. in my Python code)? Do I need to decorate the method with some type of attribute to make it web-accessible?
Take a look at the SimpleApiPlugin and BlueprintPlugin mixins whose documentation I linked above.
