Installing the same plug-in 2 times
#1
Hello.
Is it possible to install the same plug-in 2 times?
I mean exactly PSU Control I have it installed and configured to control the power supply via G-code.
In another configuration, it allows you to control the power supply via the Rapbspberry pins
Is it possible to install the same plug-in twice and configure it differently
I will be grateful for the information and if it is possible to indicate how to perform the described operation. Regards
Installing the same plug-in twice
#2
Is it possible to install the same plug twice?
It's about the PSU Control plug-in
Once installed in the control configuration via G-code and the second time by controlling the GPO pins?
If there is such a possibility, how to do it?
Regards Maciek
#3
ironically, I merged the two posts you made together :slight_smile:
From a programming point of view that would be difficult to implement. You should contact the author, modifying the plugin may be possible and/or easier.
#4
Or you could ask Santa to bring your second printer its own Raspberry Pi.
