Installing a plugin shows me "Unknown" in the popup / I can't uninstall plugins through the plugin manager (OctoPrint up to 1.3.8, OctoPi 0.15.0 or pip 10.x)
This is a known issue with pip 10+ (as also included on OctoPi 0.15.0) and OctoPrint up to 1.3.8. OctoPrint 1.3.9 will contain a fix for this, as will OctoPi 0.15.1.
A workaround until either is released is to downgrade pip to version 9.0.3, restart your server and reinstall the affected plugin through the plugin manager.
  • On OctoPi connect to your OctoPi instance via SSH, then do this:
    ~/oprint/bin/pip install pip==9.0.3
  • On a manual install:
    cd /path/to/OctoPrint
    ./venv/bin/pip install pip==9.0.3
    Then restart your server.
:memo: Note
The plugin manager by default will only show you plugins in the repository browser that you do not have yet installed. You change that though through the provided menu:
If this option is unchecked you can easily reinstall already installed plugins through the "Reinstall" button:
You can find more information about the incompatibility in these two tickets:
