I updated to 1.3.8; works fine. BUT, in the Octoprint settings, the "Save" button just has the little spinning wheel indicating it's doing something and pressing it does nothing. Basically, I can't save anything I do in Octoprint Settings. My webcam does work, but because settings is locked, I can't get any new plugins working, etc.
Any ideas?
I'm accessing Octoprint via Google Chrome on a Mac. Didn't have this problem with the last version. Rebooted the Pi3, etc. No change.
James
I'm having the same problem, with version 1.3.9. I can change some things in Settings and then save, but if I change anything in the "Intervals and Timeouts" tab, when I click on Save, nothing happens. (Normally Save will close the Settings pop-up).
I checked the permissions on config.yaml and it looks correct.
Just to add more info for ppl that might be developing plugins -
I found that if you fat-finger a data-bind value in your [myplugin]_setting.jninja2 file, you will get this infinite save button spinny behavior.
For example, I was working on a plugin that was based on another filament watching plugin (Filament Watch NG). There was a lot of code reuse and I forgot to change one of the data-bind values in the []_settings.jninja2 file, and this would happen - unable to save config changes for ANY (not just my) plugins.
