Can't get Octopi to talk to my printer
Can't get Octopi to talk to my printer. I have a Davinci Pro 1.0
Turned off printers Wi-Fi since I thought it may be interfering with the serial port connection. I also created a profile for my printer using "generic" and changed all of the settings to match my printer including build plate size, etc. I tried both the auto and the dev/ttyACMO serial port settings with auto for the baud rate.
I'm using Octoprint version 1.3.9 on a raspberry pi3. I have successfully connected to Octopi using my browser over its Wi-Fi. The terminal log of the connection process follows:
Connecting to: /dev/ttyACM0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x71b795d0, open=True>(port='/dev/ttyACM0', baudrate=230400, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Serial port list: ['/dev/ttyACM0']
Connected to: Serial<id=0x73112cd0, open=True>(port='/dev/ttyACM0', baudrate=230400, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 230400
Send: N0 M110 N0*125
Baudrate test retry #1
Baudrate test retry #2
Baudrate test retry #3
Baudrate test retry #4
Trying baudrate: 115200
Trying baudrate: 250000
Trying baudrate: 57600
Trying baudrate: 38400
Trying baudrate: 19200
Trying baudrate: 9600
Changing monitoring state from "Detecting baudrate" to "Error: No more baudrates to test, and no suitable baudrate found."
Changing monitoring state from "Error: No more baudrates to test, and no suitable baudrate found." to "Offline (Error: No more baudrates to test, and no suitable baudrate found.)"
Please format your logs, they are really hard to read otherwise.
Are they formatted properly now? Thanks
I'm not sure if that printer is supported since I remember that it apparently uses some proprietary firmware. But it can be flashed with something that works. Not sure how and what though, Google should probably be able to help though.
