C270 on Debian Stretch
Heya!
I'm trying to setup Debian Stretch in a VM (not RP) running Octoprint with a Logitech C270 as a webcam, but I cant for the life of me get the webcam working.
lsusb sees the cam just fine:
Bus 001 Device 002: ID 046d:0825 Logitech, Inc. Webcam C270
It pops as /deb/video0 when plugged in.
I´ve been largely following https://discourse.octoprint.org/t/setting-up-octoprint-on-a-raspberry-pi-running-raspbian/2337 when I get to the part where I manually start mjpeg_streamer "./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so"" I get:
i: Frames Per Second.: -1
i: Format............: JPEG
o: www-folder-path......: disabled
o: HTTP Listen Address..: (null)
o: commands.............: enabled
And the camera led lights up
But if I go to view it using the web browser, all I get a blank page that loads for ever and in the end gives up.
One of my desperate attempts was trying to follow https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=109352&p=751735#p751735 with similar results but a lesses errors when starting the streamer:
MJPG Streamer Version: svn rev: 3:172M
i: Desired Resolution: 1024 x 576
i: Frames Per Second.: 10
i: Format............: MJPEG
o: www-folder-path...: /usr/local/www/
o: HTTP TCP port.....: 8080
o: username:password.: disabled
o: commands..........: enabled
In this case I am able to access the mjpeg-streamer page at /videolan.html so the weberver starts but It´s not wanting to talk to the camera.
Any tips and hints are most welcome!
You might want to read through this entire thread and consider doing what they've suggested.
What I did on my N54L was this:
./mjpg_streamer -o "output_http.so -w ./www" -i "input_uvc.so -r 1280x960 -f 10"
The extra I did what specify a framerate and size, as well as a directory for the output.
Verify that the user starting the app can write the output directory. I recommend to move data away from program files.
The UVCIO_CTRL_MAP errors are just warning, saying that specific camera does not support that feature.
I am using the exprimental mjpeg_streamer from here:
Did not have luck with another version I tested
No luck unfortunately, I´ve tried different resolution/fps combinations that I know should work. I've also tried the different solutions discussed in GitHub without success. I`ll try a different camera I guess.
