Backup and Restore of Octoprint and plugin and their settings?
#1
is there anyway to backup the octoprint + plugins and their settings ?
we always got tf card corrupted and need to reinstall the octopi / octoprint and plugins ...
Regards
#2
What's about simply cloning the functional card?
Like descriped here
for example
#3
I agree, I'd feel much better if I could back up a few files. It makes programmatic provisioning easier.
I know the config.yaml would need to get backed up. Unsure about the plugins.
#4
I remembered that I wrote an FAQ entry on this topic a couple months back and was confused that I couldn't find it here. For some reason it apparently was lost during migration to the forum. I've recreated it:
#5
My procedure takes a bit more space cuz it backs up the whole card, even the empty space
sudo shudown now
Remove SD Card from Raspberry
Insert SD Card into card reader/computer
Run win32diskimager
Navigate to your backup folder (DON'T do this on "C" or that would be VERY BAD)
Click "READ" instead of "WRITE"
NOTES : Definition of VERY BAD... Your computer will never work again
Server is currently not running (after power outage)
#7
I really want to use the Octoprint backup plugin. (http://docs.octoprint.org/en/maintenance/bundledplugins/backup.html)
However the option is not showing up in my settings and I have no glue how to activate it.
I even set up a new Octoprintserver because I was not sure about the version I startet my operational Octoprint server with. But also under 0.15.1 the plugin is not showing up. Is there a special way to avtivate plugins of "bundledplugins"?
Thanks and regards
fakio
#8
You are using OctoPrint 1.3.9, and the Backup & Restore plugin is only available in 1.3.10 (and onwards). 1.3.10 is currently only available for testing as a “release candidate”, but once it is available as a stable version your OctoPrint will prompt you to upgrade.
#9
The BACKUP feature of 1.3.10rc2, as just now tested, produces a zip file amazingly fast. You may then download it and save it for later restoral. It seems to include everything that you'd need, minus the plugins themselves. And yet, it likely includes the settings from config.yaml for those.
